Highlighted
by Investigator
Why can’t I activate call waiting
Why can’t I activate call waiting?
12 REPLIES 12
Highlighted
by Ace Contributor
Re: Why can’t I activate call waiting
Go into Settings, scroll down to Phone and select it.
Next, you should see Call Waiting, in the Calls section. Select it and then flick the switch to turn it on.
This is how I switch on Call Waiting on my iPhone and it works fine.
Highlighted
by Profile closed
Not applicable
If it doesn’t switch on when the handset is connected using 4G, try turning 4G off first.
(Settings>Mobile Data>Mobile Data Options>Enable 4G>Off)
Highlighted
Morning @Jackie13
Thanks for posting on the community.
Has the helpful advice you have been given, got your call waiting set up?
Let us know how you are getting on 🙂
Speak soon, Leanne.
Highlighted
by Investigator
Thanks Fatboy 71 but that doesn’t work 😟
Highlighted
by Investigator
Thanks jmitchel, I’ve tried that and it doesn’t work 😳
Highlighted
by Investigator
Hi Leann-t , no I’m still not able to activate call waiting 😳
Highlighted
EE Employee
Hi @Jackie13
Are you using a pay as you go or pay monthly account?
Many thanks,
Lee
Highlighted
by Investigator
Hi lee-h. I’m on a monthly contract, how would that effect call waiting? 😳
Highlighted
by Profile closed
Not applicable
All the various EE calling features are only available on pay monthly plans.
Highlighted
by Investigator
Hi jmitchel, thanks for help. I am on a monthly contract but it still doesn’t work. 😳
Highlighted
by Profile closed
Not applicable
I’ve no idea sorry but it seems from here that several calling features no longer seem to work properly on newer EE accounts for some reason.
You will need to speak to EE technical support.
Highlighted
Morning @Jackie13
Thanks for coming back to us.
If you get in touch with our customer service team they will be able to help you with this.
Let us know how you get on 🙂
