Highlighted
by Valued Contributor
Valued Contributor
Why are NEW EE mobile and MINI WIFI customers not warned about known blackspots?
I have found a known black spot here in Edinburgh and it is large.  I estimate it to be around 8000 square feet! ...and surprisingly it is only 1 mile out of the Edinburgh City Center.
Once you step out of this black spot, 4GEE Max speeds are reached by celluar no problems and it is great.
I just want to know why the location map on the EE site does not mention this.  I had to hire a professional to check all this out.  He showed me a more accurate map of my house and the surrounding area which shows a HUGE black spot around it!
This is not acceptable, is this grounds for breaking a contract would you say ?
Any advice would really be appreciated.
7 REPLIES 7
Highlighted
Re: Why are NEW EE mobile and MINI WIFI customers not warned about known blacksp
Do you receive any service whatsoever?
Have you checked your local network for issues
Highlighted
Hi @svissloki
Could you get back to us answering @Northerner's questions?
We'll do our best to look into this.
Highlighted
Valued Contributor
Hi Northerner, thanks for replying.
I do get a signal.  On my HTC One Mini2 I get zero bars indoors, sometimes I get 2/3 bars near the window.
With my 4GEE Mini WIFI, I get speeds of 1MBPS - 3MBPS ...this gets worse in the morning when everyone wakes up and on the way to work, then at night I might get a higher speed when everyone is sleeping or at late night.
I tested the speeds outside with my 4GEE mini WIFI ...and at the cafe out of the 'black spot' , I got speeds of up to 52MBPS!!!
Highlighted
Valued Contributor
Hi Christopher thanks for your reply.
I forgot to mention that I regularly check the website for service conditions etc.
I have had these problems since I joined.
I am 100% sure its a black spot, since when I take the 4GEE mini WIFI router to outside of the 'black spot' it returns to the really hight speeds that were promised.
THere is a park across the street from my house, and when I took the router there - the speed shot right up to normal 4GEE MAX.
I am just really upset that I am in this black spot, but was not warned about before I took out a 24-month contract!.
Highlighted
Hi @svissloki
Thank you for getting back to @Northerner and I.
As you're able to get an indoor signal (even though the speed does not sound great), it wouldn't necessarily be classed as a black spot.
I recommend having a chat to our technical support team to see if there is anything that can be done.
They have access to a system that can check the performance of the masts and I'm sure they'll be able to help further.
Please let us know how you get on.
Highlighted
Valued Contributor
Thanks for the info guys, I will go speak with the technical team to see if there is anything we can do about this.
All the best.
Highlighted
Please come back and let us know what happens, @svissloki.
