by Mikeb626
Which sim after an upgrade?
Hi, so I've recently upgraded my phone (yesterday afternoon) with a new plan and phone and my new phone arrived today. Im on EE for both. All I wanted to know is if I should use my old sim in my nrw phone or use the sim that came with my new phone? I want to keep my number the same and if you ring it it still answers to my old phone, if I use the new sim will my number be transferred to it soon?
by Profile closed
Not applicable
Solution
Re: Which sim after an upgrade?
Hello @Mikeb626 a SIM swap is only necessary when the old SIM card is faulty, damaged or the incorrect size for the new device. If it is the correct size you can continue using it. 🙂
by Profile closed
Not applicable
Solution
