Highlighted
by Investigator
When will oreo be rolled out?
Any idea when android oreo will be released?
Highlighted
Solution
Re: When will oreo be rolled out?
Just got the update tonight on the Pixel XL Downloading as I  type
18 REPLIES 18
Highlighted
Depends on your handset manufacturer releasing the EE version.
EE don't  give release schedules for their firmware updates.
Highlighted
by Brilliant Contributor
Pretty sure the final build hasn' even been released yet to Google devices.
They have announced it yes but doesn' mean it' out.
What device do you have? If it' Samsung don't expect it til probably December Janruary time.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
by Established Contributor
Via EE, a lot later than you think it will.
It's only in beta on pixel's, so will be some time yet.
Electronic Engineer by day.
Geek by night.
Highlighted
by Investigator
Hi, thanks. I've got a Google Pixel, I assume EE need to check that the
release is ok before they release it to us.
Highlighted
Good Morning @fyreflye
Thanks for posting here.
This will show on your device as a notification when any new update is available.
We have no further information for this update.
Thanks, Leanne.
Highlighted
Solution
Highlighted
by Investigator
Thank you, I checked and I have it too.
Highlighted
Thanks for letting us know @fyreflye @mickthered
Highlighted
by Investigator
It seems quite good, much faster, don't mind the dot notifications, haven't
worked out the picture in picture function but not sure I'd use it anyway.
Highlighted
EE Employee
Hi @fyreflye
Do keep us updated on how you are finding it.
Many thanks,
Lee
Highlighted
by Investigator
So far so good, faster for a start, little things like being able to switch
off data instantly, quite like the notification blobs, more control over
notifications. How about you?
Highlighted
EE Employee
Hi @fyreflye
Unfortunately, my Huawel P10 gas hasn't received the notification as of yet.
I will let you know how it is.
Many thanks,
Lee
Highlighted
by Investigator
Google has released Oreo for general consumption so for those of us on Moto G5's - when are ee going to send out the OTA update for this version?
Highlighted
Hi @Demonix,
Welcome to the EE Community.
You'll receive a notification on your handset as soon as the manufacturer makes the update available for your phone.
Highlighted
by Investigator
James,
Yes - thanks I know that!
Manufacturer's release to carrier's such as ee and then it can take some time for the Telco to deploy - I want to know ETA for the Oreo update on ee connected compatible Moto handsets.
If it's longer than a couple of months and I suspect carrier will move at a glacial pace then I will just download aosp Oreo and side load on my device manually.
Cheers
Demonix
Highlighted
Hi @Demonix,
I don't think there was an EE version of that particular handset.
Where did you purchase it from?
Highlighted
by Investigator
Smiley Happy
Correct James, am on a Sim only contract.
Had assumed that Motorola / Lenovo would release OTA for Oreo then ee schedules roll out - is that not the case?
Android major revisions would not have previously been an issue as had always had Google Nexus devices but given well documented faults with Pixel series - and my 5x dieing - bought a Moto G5's instead as a stop gap as they run a virtually stock android - had thought Oreo update would have installed around now
Highlighted
Hi @Demonix,
No, EE wouldn't be involved in the roll out.
If you contact Motorola they may be able to help.
