by Mendax76 Investigator
What is ! In triangle warning on 4gee action cam
I have a triangle warning symbol with ! In it, it prevents me taking anymore pictures/videos.
What does this mean?
Solution
Re: What is ! In triangle warning on 4gee action cam
Hello there @Mendax76.
Sorry for the delay.
If you have formatted the SD card the action cam will need a factory reset.
You will need to make sure you back everything up first and then to reset you can do this in the App.
Settings >> Reset.
Let me know if you have any issues with this 🙂
12 REPLIES 12
Here is the user manual
https://ee.co.uk/content/dam/ee-help/Help-PDFs/4GEE_ACTION_CAM_UM_en_V1.0.pdf
Im looking for what you have  described still.
I couldn't find it in manual
Sent from my Samsung Galaxy S6 - powered by Three
@Richard_C @Karen_C. Can you please help with this ? I can not find anything about this triangle.
Thanks @Chris_B
Can you check the Video/Photo library is not full?
Click here for information to help 🙂
Thanks.
I've got a 64Gb micro card in my cam, I've used about 8Gb and have about 50Gb free
Mendax76
@Mendax76  Did you format the SD card before you started using it ?
Thanks @Mendax76.
I have emailed the team to see what I can find out for you
I will be in touch soon 🙂
Pretty sure I did, but I have bn using so it should be fine in that sense
Solution
Settings >> Reset.
That seams to be sorted now.
Thanks everyone for your help
Great news @Mendax76.
Thanks for letting us know 🙂
