Highlighted
by Investigator
We have an issue accessing sports.williamhill.com due to cookies
Customers are unable to access sports.williamhill.com on the EE network when using a specific IP range 213.205.nnn.nnn this seems to be due to the size of cookies?
Is there a specific limit on this proxy for that ip range?
29 REPLIES 29
Highlighted
by Ace Contributor
Re: We have an issue accessing sports.williamhill.com due to cookies
@carlbloy Are you a customer or work for William Hill? I would say WiIliam Hill should call EE and discuss it with their technical teams and they can then both work together to see where the issue is and why it seems to be only from particular IP ranges.
Highlighted
by Ace Contributor
213.xx IPs are Orange IPs.
I can access http://sport.williamhill.com using my Orange PAYG phone that has a 213.xx IP so it is just EE lines that are borrowing Orange 213.xx IPs.
Highlighted
Whose IP range 213.205.nnn.nnn is that? It's not William Hill's. What proxy?
Highlighted
by Investigator
Do you have a phone number as i've been unabel to find one?
Highlighted
by Ace Contributor
You can contact EE on 0800 956 6000 options 2, 4 if you do not have an EE number to call from or input in to the IVR system.
Highlighted
by Investigator
I believe orange use the EE network?
Highlighted
by Ace Contributor
Yes Orange uses the EE network now. Still a separate network but we use EEs infrastructure.
Highlighted
Hi @carlbloy,
Welcome to the EE Community.
I've tested the link at it's working fine on my EE mobile.
Highlighted
by Investigator
the issue we get is when you login but only if you're on a 213.205... ip
Highlighted
Hi @carlbloy,
Please take a look at @XRaySpeX's question above.
Are you connecting over the EE mobile network or home broadband?
Highlighted
by Ace Contributor
The third octet of the IP address would be more useful but I assume it's registered to Orange/EE
Highlighted
by Investigator
we're doing this over EE 4G....but as i mentioned it's only on the ip range 213.205 that we hot the issue.
Highlighted
by Investigator
in this instance the 3rd octet is 192
Highlighted
by Ace Contributor
Thanks, so it's an Orange GPRS IP address it's coming from.
Highlighted
Ah, that's better! Not all 213. range IPs are Orange but 213.205.192.x is "Orange PCS GPRS Services". Dunno if that could mean you'd get a diff IP on 3G or 4G.
@All_those_who_can_access_this_site: Are your IPs also in this range?
Highlighted
Mine is in a different range @XRaySpeX
Highlighted
by Investigator
that  does seem to be the case....yes....
Highlighted
The full range for "Orange PCS GPRS Services" is 213.205.192.0 - 213.205.223.255.
Highlighted
by Ace Contributor
Any EE line using a 213.xx IP can only be a recycled Orange IP.
Did you speak with customer service about the issue? The site has stopped responding for me completely now (Orange PAYG 213.xx IP):
sport.williamhill.com is currently unable to handle this request.
HTTP ERROR 500
The site loads correctly on my Three connection.
