by Blueie Established Contributor
Voicemail
Hello
How do I set up my own voicemail message, please, and if I wish to hear messages left for me, do I pay for that?
Any other useful information on voicemail would be welcome.
Thanks.
Steve
by Brilliant Contributor
Re: Voicemail
Your voicemail should have been set up automatically, usually a long press on the 1 key on the phone dialler will dial it for you.
Re: Voicemail
Oh, right. Thanks a lot - that was quick!
by Maestro
Maestro
Re: Voicemail
If you are on T-Mobile, your voicemail wont be set-up for you.  It's also a 2 step process on T-Mobile to activate voicemail:
1)  Dial 150 and get to the tech support menu then the voicemail option to turn on diverts.  Once enabled you will receive a text confirming, re-boot your phone.
2) Dial 121 to set-up the second part of your voicemail
Once both steps are done you can then press 1 or hit your voicemail icon to access it.
Also, on T-Mobile, voicemail is free on pay monthly but chargable on PAYG accounts.
Re: Voicemail
It's an Orange phone, but thanks for your message.
