by Pataken-55
Voicemail - turning on
Having a problem getting my voicemail to activate. When a call is unanswered, it keeps on ringing and then says the phone is currently unavailable and to try later.  Somewhere I have a setting on that is stopping the voicemail kicking in but can't work out what it is. I have a Galaxy Ace 4. Any answers would be appreciated.
Solution
Re: Voicemail - turning on
Text VM ON to 150.
Solution
Text VM ON to 150.
by Pataken-55
Thank you so much - problem solved. Regards Pataken
by stuarttunstall Established Contributor
Helped me as well... Just had my new EE SIM arrive and tested mine after reading this, got exactly the same.. text VM ON to 150 and works perfect 🙂
Quick question, although I intened to use the EE SIM in my Note 4 when I finish my Vodafone contract in a few weeks, after testing it in the Note 4 I removed the SIM to carry on using my Vodafone SIM as eveyone has my number ..
The SIM is now in my old S3 and working OK.. Will the voicemail work when I put it back in the Note 4 or will I need to text again?
Hopefully I am finishing my contract tomorrow, pay whats due, which is a month or so, and get the PAC code. and move to the excellent EE with my number... 🙂
Stuart
Yes,  VM will continue as it's associated with your number and therefore the SIM.
