by Barnesy1982
Voicemail on
Hi, How can I turn my voicemail on? I've tried everything, including texting VM ON to 150 but nothing seems to be working??
Thanks!
by Ace Contributor
Re: Voicemail on
Hello @Barnesy1982 try calling 150 and using the self serve option technical help>anything else>help with voicemail>divert calls to voicemail.
EE Employee
Re: Voicemail on
Hi and welcome to the community @Barnsey1982
Has the information from @tm90 helped at all?
Many thanks,
Lee
