by aj79 Valued Contributor
Valued Contributor
Voicemail on EE
EE Help
Text it fast & free! Text VOICEMAIL DIVERT or VOICEMAIL DIVERT OFF to 150.
Augh!!!!
How do I activate voicemail on my EE account?
Tried the pressing 1 - number not recognised.
Tried the number from another mobile, number not recognised.
Was 222 on t mobile? Not recognised.
Have iphone 5. Anyone else having issues or can suggest a number?
by dilpatel
New Member
Re: Voicemail on EE
Having the same issue. Help!
by Skilled Contributor
Skilled Contributor
Re: Voicemail on EE
I turn it off via CS as hate voice. Costs you 32 pence to call a voice mail and free to call the person back
by Ace Contributor
Re: Voicemail on EE
I believe voicemail is free on EE as I've been using it in the past weeks !!!
Skilled Contributor
Re: Voicemail on EE
Lucky you I got charged. Any way I hate the thing. More hassle than its worth
by wathman Established Contributor
Re: Voicemail on EE
I set my voicemail up by calling 222 or 07953222222.
With regards to charging the price list for ee price plans states vms is included allowance.
Here's a link to the PDF file.
http://e-gain.s3.amazonaws.com/external/content/Ts%20and%20Cs/EE_PAYM_2012%20v1.pdf
by cienzod
New Member
Re: Voicemail on EE
Hi, I spoke to customer services with the same problem, yuo need to send an SMS code to activate your voicemail which is: *5005*86*+447973100123#
Dial that number from your telephone keypad then press Call.
Now try the Voicemail button and your phone should dial EE Voicemail!
Worked for me anyway!
by traverscw
Re: Voicemail on EE
I have just spoken to Customer services the previous post is using the wrong code. Its:
*5005*86*222#
then press call, then press the voice mail
worked for me.
by Maestro
Maestro
Re: Voicemail on EE
Both those codes are actually correct, it's just the the 222 one is for T-Mobile and 4GEE whilst the other one ending in 123 is for Orange.
