by harrowtyke Investigator
Using EE Mobile Broadband with AirPort Extreme
My current internet is through BT but we don't have fibre in our area so I'm only getting 1mbs.
I currently use the BT Home Hub with wifi disabled, and hook it up to an AirPort Extreme which is the router.
I've just bought one of these...
https://shop.ee.co.uk/auth/dongles/add-pay-monthly-mobile-broadband/4gee-router/details
Can I set it up similarly, using an Apple Airport Extreme as the router?
by Ace Contributor
Re: Using EE Mobile Broadband with AirPort Extreme
Hello and Welcome to the Community.
Yes, that should work fine.
