by Expert Contributor
Expert Contributor
Update available
I keep getting a notification on my galaxy s7 edge that an update is available, I am guessing it's the August security update but when I go to setting and check for updates it say phone is up to date. I have tried tapping notification to get update as well but still says up to date!!
Has anybody else had experience of this?
Phone is running July security update at present.
11 REPLIES 11
by Brilliant Contributor
Re: Update available
Might be too many people going to download it at once.
Have you plugged it into your PC and used Smart Switch. This should bypass all that.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
Expert Contributor
@BrendonH I don't have a PC! I have been getting the notifications every 2-3 days for last couple of weeks, different times of day, so I don't think lots of people downloading it at same it is viable option!!
OK then put your phone into recovery mode and clear the cache
Expert Contributor
Did full hard reset this morning.... Notification came up again at 4pm this afternoon 🙁
Dial *#1234# and share the info please.
Expert Contributor
Ap g935fxxs1dqg8
Cp g935fxxu1dqd7
Csc g935fevr1dqd1
You have the most recent firmware installed with the most recent security patch. (According to Sammobile who is always very reliable)
So they have not released the August patch to you yet.
This device on EE last updated on 31/7/17.
So you have another issue of it notifying you of an update that isn't actually there.
Sure it's not play store or Samsung telling you some apps need updating?
@Northerner wrote:
I can believe that its stating the phone update as it did happen to me once on my S8+ but then it updated a couple days later so I put it down to servers being busy.
Expert Contributor
Thank you for your input guys, it's definitely a software update notification.
Morning @Rogersdave771
Thanks for coming here.
In this case I would suggest giving us a call if the reset has not resolved this for you.
Our technical support team will be able to look into this for you.
Thanks, Leanne 🙂
