Highlighted
by Investigator
Unidentified Network, No internet
Okay. So I recently got a fibre internet connection with brightbox 2, and since then ethernet hasn't worked. I have tried wifi and it works on all devices. But specifically on my PC the ethernet won't work but previously did with my old ethernet. On my smart TV the ethernet works fine.
When diagnosing the connection it says that it doesn't have a valid IP adress. Tutorials on the internet aren't helping me at all.
Highlighted
Solution
Re: Unidentified Network, No internet
Try plugging PC into a diff LAN port of router.
What does it say in the Currently Connected Devices section on the initial Status page of the BrightBox after you log in?
7 REPLIES 7
Highlighted
Solution
Highlighted
by Investigator
Well that fixed it actually. My friend had decided to switch the ports for absolutely no reason.
Highlighted
Means router is faulty with at least 1 unserviceable Ethernet port.
Highlighted
by Valued Contributor
Valued Contributor
Was it plugged into a WAN port by mistake?
Highlighted
@leenowell: The WAN port is just 1 of the LAN ports.
Highlighted
by Investigator
It was plugged into that one red one.
Highlighted
Sorry, @leenowell & @SKOOT4life, I was forgetting. The red port is WAN & it's not LAN.
