by xeulbnc
Under what situation will my EE Pay As You Go Sim card get inactivated?
I am out of UK/Europe but trying to keep my SIM card activated for important contacts. Does anyone knows how long if I dont use it or under what situations will the sim card get inactivated? Or what should I do to keep it activated while minimising the cost as much as possible.
Solution
Re: Under what situation will my EE Pay As You Go Sim card get inactivated?
Hi @xeulbnc,
Thanks for joining the EE Community.
You can find out everything you need to know in our pay as you go hibernation article.
Hope this helps.
by Brilliant Contributor
You got to make 1 chargeable call or text every 6 months to keep it active.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
Solution
Hi @xeulbnc,
Hope this helps.
