by DesertFox Investigator
Transferring Number to Different Sim
I'm currently with EE but am changing to a device that does not use a micro sim, is it possible that I may retain my current number? I want to sick with EE of course.
Regards,
Fox
by Profile closed
Not applicable
Solution
Re: Transferring Number to Different Sim
Hello @DesertFox if your device just requires a different sized SIM card to the one you have you can take either the old SIM card or photo ID in to store and they will give you a replacement of the correct size free of charge. You can also order a replacement over the phone by calling customer service on 150 from
an EE phone or 07963 966 250 from
any other (lines open at 8am) or using this form online, however there is a £10.20 charge for both of these options. :):
https://myaccount.ee.co.uk/order-sim/
by Profile closed
Not applicable
Solution
Thanks for the speedy reply Tom! I'll get right to that as soon as possible 😊
by Profile closed
Not applicable
You are welcome @DesertFox come back to the community anytime if there is anything else you would like to know. 🙂
