by Melj Investigator
Track my kid app
Hello. I have the track my kid app on my phone and track my son when he is out and about. Does this use up our data/4g. Thanks
Re: Track my kid app
It will tell you on the app support page, however as both phones will need to connect to the network (4G or wifi) then yes data will likely be used.
by Ace Contributor
It will use a tiny amount of data to transmit its location so you find where your son is,
Thanks for your reply.  Much appreciated.  Mel
EE Employee
Hi @Melj and welcome to the community.
Please do follow the advice given above, do let me know how you get on in your findings.
Many thanks,
Lee
