by HollyR
Switching phone numbers between different providers
I have two phones with different numbers, both on different providers (Virgin Mobile & EE). The EE one is halfway through its contract and I'm just about to upgrade the Virgin one. However, once the Virgin one has been upgraded, I want to switch the numbers from the current Virgin phone to the EE phone, and the EE phone to the upgraded Virgin one. How can I do that?
by Prodigious Contributor
Solution
Re: Switching phone numbers between different providers
This is not possible.
Once you use a PAC code it will cancel the contract for that providor you are moving the number from.
You are unable to just swap the numbers over.
Barry
Here to help
Solution
Barry
Here to help
by HollyR
Okay - thanks anyway!
