by kylechapman21 Investigator
Re: Slow 4g speeds
it could be a network issue or it could be that the network mast could be having problems with the connection. you could try going to settings carrier select any network apart from EE eg like vodafone or o2 then go back and select EE if that don’t work try taking sim card out of the device and putting it back in then you could try pressing the power botton and the home botton for 15 minutes and release when you see apple logo the phone should restart if that doesn’t work try reset network settings in general scroll to the bottom and you see reset network settings the iphone will restart and come back on that will refresh the network you should see a better improvement on you speed and internet connection.
