Highlighted
by Contributor
Since mid morning none of my wireless devices can access router !
Since mid morning none of my devices can access the 4gee router wirelessly even though the router shows the wireless light and has a signal. PC can connect via LAN cable and speeds slower than normal. What’s happened and how do I rectify it?URGENT! We depend on this....
14 REPLIES 14
Highlighted
Re: Since mid morning none of my wireless devices can access router !
Tell the devices to Forget the MBB router's SSID & reconnect afresh supplying WiFi pwd.
Are you sure it's the WiFi connection that's not working & not that the devices can't connect to the Net? Check in the router for its list of connected devices.
Highlighted
by Contributor
Re: When can I cancel my contract
And what about if I’m a few months into the contract but your router has ceased working properly as happened this morning through no fault of mine!😡 sale of goods act
Highlighted
by Contributor
Many thanks for your prompt mail. The MBB device now isn’t listed on any of my wireless devices only on the desktop PC when connected by LAN. It’s the wireless devices that need to be able to find the MBB and they can’t!
Sent from my iPhone
Highlighted
by Profile closed
Not applicable
Sorry if this sounds stupidly obvious, but have you tried turning the route off and then back on again?
Highlighted
Welcome back @Nemo2739
Please try @Profile closed's advice and restart the router.
If it isn't working after the restart, please try forgetting the WiFi connection of each of the devices before re-setting them back up.
Let us know how you get on.
Highlighted
Hi @Nemo2739
I see you have been given some advice on your other post, please take a look and get back to us.
We'll do our best to help you.
Highlighted
by Contributor
To all those helpful people who have suggested that I unplug the router and start over - I have done it several times and still no wireless functionality even though the wireless icon lights up!!!!!!
Highlighted
Thanks for confirming, @Nemo2739.
The advice was given with the best intentions, this is usually the first thing our technical support team would advise if you were to contact them.
I recommend speaking to our technical support team. They will be able to run through some troubleshooting with you to try and get you back up and running.
Highlighted
Posted in the open:
@Nemo2739 wrote:
Thanks for your advice on my non functioning 4gee router. Re your suggestion: How do I check the devices listed in the router when no instructions supplied with it and no obvious way of doing it? Is this something I have to do using windows 10 on desktop whilst connected to router via LAN cable ?
Highlighted
Login to the MBB router at http://192.168.1.1 as user "admin" pwd "admin" & navigate its menus for Connected Devices. On mine it's under Connection / Connection Status.
Do this from the wired PC.
While you are at it check the WiFi Settings are what you think they are.
Highlighted
by Contributor
Fraud this didn’t work. Couldn’t get to a screen which flooded me to login as ‘admin’. Am getting really fed up now and am going to phone 07953966250
Sent from my iPhone
Highlighted
Let us know how you get on @Nemo2739
Sorry to hear of your frustration.
Cheers
Richard
Highlighted
by Contributor
Dear All,
Problem solved by nice and helpful engineer. Had to reset router by flicking opening at side and prodding in, using a paper clip - in similar way to opening the SIM tray on an iPhone. Won’t forget it now. Happy!!!
With grateful thanks to all for support and advice - give you all 10 out of 10 for that.
Trudi
Highlighted
Hi @Nemo2739
Thanks for taking the time to share this in the community.
Because I loved the support you gave today, I'd like to send you a gift voucher so you can treat yourself.
I'll send you a private message in a moment with further details.
Keep up the great work – it’s the people here who make this community a great place to be!
Richard
