by Captainmidget1
Sim card
I was wondering with the SIM card, because I use to have a larger SIM card that was used in a Samsung phone and then got an iPhone 4s, I have to take the pieces off to get the smaller SIM card, but now I can't find the other pieces. Is there anyway I can just buy another SIM card and use that outing part? Or buy a new sim without having to change any of my information on it?
Solution
Re: Sim card
@Captainmidget1  Just go to a store and request a replacement SIM card.  Your number will get migrated to this new SIM card.
Solution
Re: Sim card
