by Liam1956
Sim card from a Sony Eriksson to a Samsung
My son gave me his Samsung mobile to use.  How do I change the 'big' Sim card from my old Sony Eriksson to the smaller Sim in the Samsung?  I want to transfer my contacts list over.
by Liam1956
Solution
Re: Sim card from a Sony Eriksson to a Samsung
Hello
thanks for the prompt reply.
The Eriksson Sony phone's sim card cannot be broken down to fit the Samsung.
I have contacted EE customer services and they are sending me a micro Sim, then I am to call them on another line to set up the new Sim with my contact numbers.
by Ace Contributor
Hello @Liam1956 is your SIM card an EE triple cut SIM card? When you look at it you should see three sizes in one - the green outer border can be snapped off to make a micro SIM card then the yellow border can be snapped off leaving just the white nano SIM card.
by Liam1956
Solution
Hello
by Ace Contributor
Excellent I am glad they were able to assist further. I hope your new SIM card arrives soon.
Hi @Liam1956,
Thanks for joining the EE Community. Smiley Happy
Please let us know if you need any help getting set up once your new SIM card arrives.
