by Skilled Contributor
Skilled Contributor
Signal Boosters , what is the best or waist of time (and maybe money?
on the google play page you can find many so called "Signal Boosters" what is the best one or are they all a bit a waist of time, space or money? (I am using a 4G Nexus 7)
by Brilliant Contributor
Solution
Re: Signal Boosters , what is the best or waist of time (and maybe money?
They are all a big waste of time/money.
If you can't get any signal at home you need to ring EE and ask for a signal box.
Brendon
If you think I helped please take time to press the button below
Community guidelines
EE Contact Details...
150 from EE Mobile
0800 956 6000 (Option 5) from any other phone
0800 079 8586 Home Broadband & EE TV
Solution
Skilled Contributor
sorry maybe i wasn't clear it is not about the Wifi signal but about the 3g / 4G signal
by Problem solver
Problem solver
Hi!
The responses you've had are about the 3G/4G signal.
The signal box is a device which provides indoor 3G coverage, so would help if your problem was localised - check this link: Signal_Box
Software "boosters" are generally ineffective for enhancing mobile signal.
Skilled Contributor
see we are still cross purposes here i mend signal boostersapps that you can install on your phone/ tablet for a beter 3G or 4G signal (for example https://play.google.com/store/apps/details?id=com.Digitalnet.signalboosterFree but there are many more) but i guess they are all a bit a waist of space
I give up.
Bye.
There is no cross purpose here.
Signal booster apps are a waste of space.
What we are saying is if you are unable to get signal at home then your best bet is to ask for a signal box.
This won't give you 4G signal but it will give you signal.
Brendon
150 from EE Mobile
Recent solutions
