by huzaifabod Contributor
Seven-Day pack top up
Hi there!
I was interested in applying for the £1 seven-day data pack and was wondering how to top up. It is possible to top up by using a E Voucher?
by Profile closed
Not applicable
Solution
Re: Seven-Day pack top up
Hello @huzaifabod yes you can top up other ways than using a credit card as mentioned in the link I provided. The minimum top up amount on EE is £5, it is not possible to top up your account £1 at a time. 🙂
8 REPLIES 8
by Profile closed
Not applicable
Hello @huzaifabod yes you can top up by a minimum of £5 using an e-voucher. Here is a link containing all the ways you can top up on EE PAYG. :):
http://ee.co.uk/help/accounts-billing-and-topping-up/pay-as-you-go-top-ups/ways-to-top-up
So cant u top up a seven day data pack without a credit card?
so cant u top up weekly for a £1 data pack without credit card?? @Profile closed
by Profile closed
Not applicable
Solution
Cheers mate
How much mins, texts and data do u get from £5? @Profile closed
by Profile closed
Not applicable
You are welcome @huzaifabod come back to the community anytime if there is anything else you would like to know. 🙂
by Profile closed
Not applicable
Hello @huzaifabod you can use £5 credit to buy 5 weekly packs of your choice, or there is a 30day £5 everything pack giving 50mins 250texts and 150mb as well. You can also use the credit to buy minutes/texts/data add ons that start from £1. Here is a link containing the packs and add ons available on EE. The 30day £5 everything pack is not listed, but the code to text is EP5 to 150. :):
http://ee.co.uk/help/my-account/pay-as-you-go/pay-as-you-go-packs-how-they-work
