Highlighted
by Investigator
Setting up Peel remote on Samsung S6 with EE box
Hi all,
I'm trying to set up my EE box with peel remote on my Samsung S6, I've used this before on my previous boxes but can't seem to get it set up with the EE box.
Thanks in advance
14 REPLIES 14
Highlighted
EE Employee
Re: Setting up Peel remote on Samsung S6 with EE box
Hi @Animallover20 and welcome to the Community.
The EETV box will not connect to any universal remote only the one that is provided.
Many thanks,
Lee
Highlighted
by Investigator
Hiya, thanks for replying to me, I've managed to get it  set to turning the channels but I haven't got the TV guide that was there before as I changed my TV provider service, so I guess that did it lol.. Ooh well 😊
Highlighted
EE Employee
Hi @Animallover20
Brilliant news, How did you manage to connect the device?
Did you use the generic branding codes/software?
Many thanks,
Lee
Highlighted
@Lee_H.  I use  THIS., this is a bit more than a universal remote as you need the original remote to program this remote.     I was using 3 remotes at one point now I'm just down to this.     This will work with the EEtv box because you program it from the original remote.    Cheap too.
Highlighted
EE Employee
How many devices can the remote learn @Chris_B
Many thanks,
Lee
Highlighted
by Investigator
Hi Lee, yeah I couldn't find the name of the EE box in the list of "add your device " which I did it under "set top box"  so I changed the TV service provider and went back into the "add your device" and it was there, bit strange so was able to add it, but as I said I can't get the TV guide listing now lol..
Highlighted
by Investigator
Hi Lee, yeah I couldn't find the name of the EE box which is called Netgem in the list of "add your device " which I did it under "set top box"  so I changed the TV service provider and went back into the "add your device" and it was there, bit strange so was able to add it, but as I said I can't get the TV guide listing now lol..
Highlighted
EE Employee
Very strange @Animallover20
@Chris_B does your remote work with the EPG
cheers
Lee
Highlighted
by Investigator
Yes it is a bit strange, now that is gonna bug me lol 😈
Highlighted
@Lee_H  Works on freeview and Virgin TiVo box.    And my sound bar that I can not program the virgin remote to control.
Highlighted
@Chris_B@: wrote:
I use  THIS.,
Linky does not compute. I think you mean CkeyiN®Universal English Smart Remote Control Controller With Learn Function For TV CBL DVD SAT .
Highlighted
@XRaySpeX   Thanks.  I never checked the link to make sure it worked.  That'll teach me.
Highlighted
Highlighted
EE Employee
