Highlighted
Server down Can't make calls or texts
Can't make calls or send texts
Highlighted
by Ace Contributor
Re: Server down Can't make calls or texts
Hello @Steph1878 is it just you or are other users in the area affected as well?
Tried restarting your phone? Is this indoors or outdoors?
Check the Network Status Checker for any faults:
https://myaccount.ee.co.uk/networkchecker/checkservice
Highlighted
Hello there @Steph1878
Thanks for posting on the community.
Using the link @tm90 has helpfully provided, do any problems show in your area?
If not, what phone are you using?
Speak soon, Leanne 🙂
