by Cedrik Established Contributor
Second Sim to use as Data only / shared Data ?
I currently have a Sim only plan with lots of Data and I bought a 4G router to see whether it would work with my Sim - it did. Swapping the Sim over from the phone to the router is a bit of a pain though.
Can I get another Sim just for the Router and share the Data I have on my current plan ?
Or is this 'Data gifting' thing about to happen ?
I'm looking for the cheapest option as I'm paying a fair bit for my plan as it is.
by Ace Contributor
Re: Second Sim to use as Data only / shared Data ?
@Cedrik You can get Data Share sim for that you need to call 0800 956 6000 or 150,
And more information can can be found here Shared Plans ,
Cheers, yes that seems to be an option.
Is it called a 'Sharer Sim' and it includes unlimited call  / texts for £13 a month on a contract (if I'm correct) ?
by Ace Contributor
HI,
@Cedrik No you can just ask for data share sim for tablet or wifi dongle.
I am not sure about price (i think it around £8 a month), call on above numbers and you can get all information that you required.
Many Thanks
Hi again,
Not sure if that option is still available, the chap I spoke to earlier said they'd phased out data share sims (?)
That's right @Cedrik, the data SIM shared plan has been discontinued.
