Highlighted
by Investigator
Samsung s8
 Hello. I recently got a new phone Samsung S8 on ee. I have a problem, every time i put my data on i can't send any pictures(whatssap,messenger,anywhere) i also can't load any received pictures. If i go on wifi everything works fine. I went to ee and they said it may be the sim card and i they gave me the another one. The problem is the same. Does anyone knows why and how can i fix it? Thank you
8 REPLIES 8
Highlighted
by Investigator
Re: Samsung s8
Hello. I didn't manage to fix the problem yet. I spoked with an agent last
night and he said he will have to investigate. Don't know what else i could
do.
Highlighted
by Investigator
Samsung s8
 Hello. I recently got a new phone Samsung S8 on ee. I have a problem, every time i put my data on i can't send any pictures(whatssap,messenger,anywhere) i also can't load any received pictures. If i go on wifi everything works fine. I went to ee and they said it may be the sim card and they gave me the another one. The problem is the same. Does anyone knows why and how can i fix it? Thank you
Highlighted
Re: Samsung s8
Are you on contract or PAYG? If PAYG, do you have credit to send MMS using the Messenger app? They are not included in your text allowance. N.B. This does not apply to Whatsup which uses your data allowance.
Highlighted
by Investigator
Re: Samsung s8
Hello. I am on a contract
Highlighted
Re: Samsung s8
@Krisztina26   Have you allowed the apps to use cellular data ?
Highlighted
by Investigator
Re: Samsung s8
Yes i did.
Highlighted
Re: Samsung s8
Hi @Krisztina26
If you cannot send anything when not on wifi then this is a data related issue. Does your phone say 4G at the top of the screen?
  • Do you have this problem in only one place? Are you in a 4G area?
  • Have you checked your local network for problems?
  • On the quick shortcuts make sure "Mobile data" is active (should be blue)
  • Settings - Connection - mobile networks - Network Mode should be LTE/3G/2G (auto connect)
  • Try downloading your Internet settings from here.
Thanks,
Highlighted
Re: Samsung s8
Morning @Krisztina26
Has the advice from @Northerner helped get this working for you?
Speak soon, Leanne 🙂
