by soni13782 Investigator
Samsung Note 8 Dual sim wifi calling
Can somebody please confirm. If you have Samsung note 8 dual sim bought from Samsung. are you able to use wifi calling?? or not??
Please need information urgently.
Thank you,
7 REPLIES 7
by Expert Contributor
Expert Contributor
Re: Samsung Note 8 Dual sim wifi calling
@soni13782 as far as I am aware WiFi calling is only available on phones that have come direct from EE and running EE firmware. 😕
@Rogersdave771 Can we not use EE firmware on phone bought from Samsung?
Expert Contributor
@soni13782 no unfortunately if phone is not purchased directly then you can't run EE firmware.
@Rogersdave771 oh ok, unfortunately, I won't be able to get wifi calling if I buy from Samsung.
Expert Contributor
@soni13782 ee don't do duel sim but they do do note8.... It's the phone I am getting after contract is up on S7 edge 👍
You don't need EE firmware for VOWIFI on most Samsung models which run BTU (UK) firmware. Mine doesn't run EE firmware and VOWIFI works fine.
As for the UK dual sim, I cannot say for sure but I would suspect not as the phone has two active sims. You could always ask Samsung and if purchased online return it within 14 days for a refund.
by deebo007 Contributor
I have a Dual Sim Note 8 direct from Samsung. EE wifi calling works absolutely fine on it.
