by Wardy1
SIM
Hi I upgraded from orange to EE, I received anew phone and SIM but I've lost the letter with the sim number, what do I need to do, as I upgraded is my sim automatically activated within 24 hours, , my account online is still showing my old contract terms. Many thanks
by Ace Contributor
Solution
Re: SIM
The SIM number should be printed on the card itself. See the picture below:
Usually if it was a Nano sim card, you can ommit the initial few digits.
W
by Ace Contributor
Solution
Re: SIM
W
