Highlighted
S8 usb connector fault
Yesterday my galaxy S8 kept telling me that the usb port had moisture detected in it. It has not been near any water. today the phone keeps showing a notification of "usb connector connected" then "usb connector disconnected". This keeps the screen open instead of going dark. There is no lead connected and I cannot charge via the lead. To ensure my phone charges I have to turn it off as the notification drains the battery. Anyone else had this or know of any way to fix it. Thanks
Highlighted
Re: S8 usb connector
Good morning @Nandlj.
Welcome to the community. 🙂
Has the USB connection error only been coming up since the moisture detection error appeared?
Look forward to hearing from you.
Chris 🙂
Highlighted
Hi yes that is correct
Neil
Highlighted
Thanks for confirming, @Nandlj.
I recommend getting in contact with our technical support team, they will do their best to fix this.
Please let me know how you get on.
Chris 🙂
