Highlighted
by Investigator
S8 + call answering problem
When I try to ansa a call on my s8+ it hangs up instead can anyone help I've had a sim replacement so It's not that.
Highlighted
Re: S8 + call answering problem
Are you using the network (3G/4G) or connected to VOWIFI when this happens?
Does it happen with all calls regardless of location 'at home and away from home)
Highlighted
EE Employee
Morning @Mez01
Welcome to the Community! Smiley Happy
Just in addition to @Northerners questions - are you able to try your SIM in another phone?
Thanks - Karen. Smiley Happy
Highlighted
by Investigator
3 4 g and WiFi. Also now fone is to ringing  3 times and drops calls. Voicemail has been turned off ive had a new sim.  The phone won't let me call 150 🤤
Highlighted
by Investigator
I've tried the sim in another phone working fine. Just dropping calls now on my phone.
Highlighted
EE Employee
Hi @Mez01
If the SIM works in another phone it sounds like it's a device issue.
Try putting the phone in safe mode - following these steps:
  1. Turn the device off.
  2. Press and hold the Power key past the model name screen.
  3. When “SAMSUNG” appears on the screen, release the Power key.
  4. Immediately after releasing the Power key, press and hold the Volume down key.
  5. Continue to hold the Volume down key until the device finishes restarting.
  6. Safe mode will display in the bottom left corner of the screen.
  7. Release the Volume down key when you see Safe Mode.
If you have no issues in safe mode - it's something on the phone that's causing the issue.
It would then be a process of elimination to figure out what it is.
Let me know how this goes.
