Highlighted
S6 update
Ok it's been over 4 weeks since ee said the nouget update will be out in couple of weeks ,
So where is it
Waiting for the fixes for s6 in this update . Taking to long as all other networks have had this for ages
Highlighted
Re: S6 update
It will be available when your phone tells you it's available. You know from the other thread you posted on,  EE don't say when software updates will be available.
Also the battery was poor generally on the S6 regardless of installed firmware.
Highlighted
by Skilled Contributor
Skilled Contributor
Re: S6 update
I take it you mean by "all other networks" Vodaphone? As Vodaphone are the ONLY UK network with Nougat on the S6.
Virgin, O2, 3, EE and even UNBRANDED handsets do not have it yet.
EE are not the fastest and have never had a great track record with updates but Samsung have not even released this to unbranded customers yet.  There is rumours of a serious flaw with the update hence it's delay in the UK.
You need to ask Samsung what is going on first...    Once unbranded BTU is out THEN you have the right to hound EE for information. At the moment you should be venting to Samsung..
