by 1oldgit Contributor
Router login
I have my own router rather than one from orange.
My freeserve address is needed to log in to my internet connection.
Will I have to change this address because of the orange closure?
I have already set up and am using a new email account.
Solution
Re: Router login
No, your BB Username is not affected by the email closure. Altho' it resembles your Freeserve email addy, it is just a unique string of chars that IDs you to the EE servers.
10 REPLIES 10
Solution
Re: Router login
Re: Router login
Thanks XRaySpex.
Re: Router login
You're welcome :)! Glad I could be of assistance.
Re: Router login
I've been having second thoughts on this.Perhaps I didn't give enough info?
I have an old Netgear DG834G router.When I want to check settings etc. initially the server asks for my username and password-no problem with this.Then Under Basic Settings I see:
Login:  me.freeserve.co.uk@fs
Orange Password: ************
which is the part I am asking about.
This is not the same as the string of characters I have to give others to access my router and which appears under Security Encryption.
Just trying to make sure I'm not left high & dry on 31st May!
Re: Router login
Yes, it isn't same. The latter are the WiFi creds, SSID + pwd. These are completely independent of the BB login & your email addy and cannot be affected by the email closure on 31 May.
Re: Router login
Hi @1oldgit
This sounds like you are describing your WiFi password, which wont change, so do not worry.
Cheers
Richard
Re: Router login
Thanks once again XRaySpex for sharing your technical knowledge.I apologise for including any irrelevant info.
Re: Router login
Thank you Richard.
Re: Router login
My pleasure @1oldgit
Always here to help if we can.
Richard
Re: Router login
It's OK. I misread your post at 1st. I thought you were using the DG834G just for checking the settings rather than as your main router.
You should phone EE for a Brightbox. It's a bit faster than the DG834G but you can't tweak the NM if that's what you are doing.
