Highlighted
by Established Contributor
Reward for safe return of missing ringtones and notifications (S8 Oreo update)
Hey hey
Has anyone seen my stock ringtones?  They went missing last night just after my S8 received the Oreo update.  I've looked everywhere including system folders, but I just can't find them.
With another cold snap forecast I am getting worried for their welfare...  I'm also getting frustrated trying to find out why they aren't where I left them before the update!
Anyone have any suggestions?
Many thanks
Worried and concerned of Vauxhall!
Highlighted
Solution
Re: Reward for safe return of missing ringtones and notifications (S8 Oreo updat
@vauxhall
Right I think I might know what you have done. Go into settings - Apps -Then click on the three dots and choose "reset app preferences"
Then settings - sounds and vibration = ringtone and they should be a long list of default tones.
12 REPLIES 12
Highlighted
@vauxhall  Welcome back.  Perhaps @BrendonH can help with this.
Highlighted
Hi @vauxhall
They are still there under volume settings. If not then try clearing your system cache in recovery and restarting. If that still doesn't work factory reset.
I have also upgraded to Oreo and I have checked, they are still available.
Highlighted
Hi @Northerner
When you say they are 'under volume settings' I'm not sure what you mean...  it's the actual ringtone / notification files I'm missing rather than being able to adjust the volume of them.
Currently I'm able to use the sounds I'd downloaded and been using for the last year, but I can't access any of the stock files.  Yet my alarm clock app can see and use them...
Highlighted
@vauxhall
If they are not selectable under settings -sound and vibration then clear the system cache under recovery or factory reset.
Highlighted
by Expert Contributor
Expert Contributor
@vauxhallwrote:
Hi @Northerner
It should be Settings, Sounds & Vibrations, Ringtone
Or
Settings, Sounds & Vibrations, Notification Sound.
You should then get a list including the system sounds and any you've added. If not then let us know what you do see.
Highlighted
Hi @vauxhall,
Did you manage to find your ringtones following the great advice from your fellow community members?
Highlighted
When I go into either Ringtone or Notification Sounds under "Sounds and Vibration" I'm offered a list of folders.  The Ringtones and Notification folders have one or two files, not the full list.
I don't have an SD card in the phone, so everything is on the device.
Cheers
Highlighted
Solution
@vauxhall
Highlighted
Thanks, but what do you think I've done?  I haven't made any changes to settings since the update.
That said, it's worked... now I just have to set up permissions on all the apps again!
Cheers for the help, @Northerner
thanks
Highlighted
@vauxhall You are more than welcome as that's what this community is about.
This occasionally happens with updates and I have seen it before. It's a strange one as system links shouldn't need or ask for any preferred app to open. You know how to fix it now anyway and the reset app preferences is handy tool.
Thanks.
Highlighted
EE Employee
Hi @vauxhall
I'm glad you got sorted using the wonderful advice from @Northerner.
Cheers
Lee
Highlighted
Expert Contributor
Thanks.
It could be an app. You tap to change a sound in an app, it pops up at the bottom of the screen asking you to choose between the system sound picker or a file manager (like "my files" or "Documents" - so you can navigate to the folder with your custom tone), you accidentally tap "Always" instead of "Just Once" and the handset thinks you want to always use the file manager instead of the system sound picker.
This can be a handy workaround as some Android skins don't have a browse option in the sound picker. (Not the case here)
