Highlighted
by Investigator
Recently swapped number over, says it's complete but can't make any calls
Swapped number over from Three, it says it's complete but can't make any calls
7 REPLIES 7
Highlighted
by Brilliant Contributor
Re: Recently swapped number over, says it's complete but can't make any calls
Have you turned your Three mobile off and restarted your new one?
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
by Investigator
Thanks, tried that.
Highlighted
EE Employee
Hi and welcome to the Community @Sos1989
So I can try and assist, may I know the following:
  • Is It porting in day today?
  • What type of handset it is you have?
  • Is it only calls and texts that are affected?
Many thanks,
Lee
Highlighted
by Investigator
Yes today, I had a text this morning to say it was complete. It's a 7+ and it's calls/texts any My EE app won't recognise the number to register. I can use my internet data
Highlighted
EE Employee
Hi @Sos1989
Please can I get you to
  1. Go to Settings.
  2. Tap Phone.
  3. Tap My Number.
  4. Use the delete button to remove the old number.
  5. Use the keypad to enter the new number.
  6. Tap Save.
  7. Restart the iPhone.
Let me know how you get on with that first.
Many thanks,
Lee
Highlighted
by Investigator
Still no good. I'm getting 'you've dialed an incorrect number', no matter what number I try to call, including EE numbers
Highlighted
EE Employee
Hi @Sos1989
As the suggestions have not worked, please pop to the live chat link and speak to our technical team.
This can be found on our Get in touch page, under the EE drop down menu.
The link will be active from now till 9pm (UK TIME).
Let me know how you get on.
Many thanks,
Lee
