by IrvineMccreight Established Contributor
Re: Fiber Plus away below standard
@IrvineMccreight wrote:
Fiber Plus update
Fiber plus away below standard ?
Irvinemccreight
Solution
@IrvineMccreight: Welcome to EE's Home Broadband Forum.
If you would like help with your speed or connection issues, please would you carry out the steps and provide the data as requested in the Need Help with Your Home Broadband Speed or Connection? sticky. This will enable us to diagnose the problem and advise you further.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
6 REPLIES 6
Solution
Hi @IrvineMccreight
Thanks for coming to see us in community 🙂
Please answer the questions @XRaySpeX has posted to you and he may be able to help you further.
Richard
Fiber Plus Brightbox 2 upload and download 35mbps 14mbps not exceptable
Fiber Plus Brightbox 2 upload and download 35mbps 14 mbps not exceptable can you help?
Irvinemccreight
by Star Contributor
Star Contributor
Re: Fibre Plus Brightbox 2 upload and download 35mbps and 14mbps not acceptable
Care to provide detail as to why it is unacceptable?  The guys that help on here are good but they are not mind readers. PS no-one on here speaks for EE - you need to ring EE customer services.
Edit: Irvine, I have just noted your previous posts - each time someone volunteers to help you then don't provide any information.  "Please" often goes down well too.    I think you had better sort out your own problems.
Re: Fiber Plus Brightbox 2 upload and download 35mbps 14mbps not exceptable
@IrvineMccreight: We're still waiting for some info. from you so we may advise you. I'll remind you again:
Hi @IrvineMccreight
What is your expected download speed?
Also, please check out @XRaySpeX's brilliant home broadband support article.
We'll do our best to help.
