Highlighted
by Investigator
Problem with unlock. Wrong code
Hi  (sorry for my language)
I have problem with my unlocking code.  It's incorrect. I've got e-mail with unlocking code but code not working and IMEI is wrong. A call few times and nobody can't help me. Now I'm on holiday and I can't use my phone 😕
11 REPLIES 11
Highlighted
Re: Problem with unlock. Wrong code
Hello there @ziomek91
Thanks for coming here.
What device are you using?
Also are you using another network SIM to unlock this?
Thanks 🙂
Highlighted
by Investigator
Samsung s7 Edge. Yes i tryed o2 and Three
Highlighted
@ziomek91   Can I just ask are the other network SIM cards activated?  If there not it will not work at all as you can not activate a SIM card when your outside of the uk on a roaming network.
Did you get this device yourself from EE ?
Highlighted
by Investigator
Yes is activated. I tryed in uk unlock . Yes i have phone with me. Sombody send me incorrect code because nr IMEI it's different than IMEI my phone. Do you need my IMEI?
Highlighted
Have you had the device replaced for the IMEI to be incorrect?
If so was this replaced through us?
Thanks.
Highlighted
by Investigator
[Mod edit: Please do not personal information on the community]
My  IMEI **************
I got this meil from EE.
Please find the unlock codes and process for your Samsung device below:-
IMEI – ***************
Code –  ********
Important Note: Please only follow the procedure once.  Should you encounter any problems please don’t hesitate to contact customer services.
Unlocking process using a different network SIM card
Insert a different network SIM card and switch on ( 02 or Vodafone works best)
The handset should display: ‘Network lock’ or ‘Enter password’
Enter in:  74682841
Press OK
Your device should now be successfully unlocked. If not, please continue the process below.
If your device shows “Network Unlock unsuccessful”, please switch it off and on, then enter in 53853806
This may show nothing on the screen when entering, or give a similar error message.
Once that has been entered please then input74682841  once more.
Highlighted
Hello there @ziomek91.
In this case you would need to get in touch with our customer service team.
They will be able to look into this for you.
Thanks very much!
Highlighted
by Investigator
I speak few Times! My friends same his English is very well.  And nobody can't help us. I send mail to person ho send me codes and he don't send me any mail.
Highlighted
EE Employee
Hi @ziomek91
If the IMEI is incorrect, you will need to speak to customer services.
Have you tried to reply to the email address that has contacted you?
Many thanks,
Lee
Highlighted
by Investigator
Yes I  reply for this massage few days ago.
Highlighted
EE Employee
Hi @ziomek91
Please do give customer services a call and they will be able to look into this further for you.
Many thanks,
Lee
