Highlighted
by Contributor
Phone still not unlocked
The same problem here did try to unlocked them last year I had fill the unlocking form. Then I got a message it is unlocked, but never tried to put any other network SIM card. So last week I try to put another SIM card (different network) it just says no service no way there is no signal as the current SIM card has a serve with the different phone. So what I did thinking maybe it wasn't unlocked, so I did fill the unlocking form again , after a few days which is today it says details been checked that the phone was unlocked , still won't recognised any sim. Need to be sorted Pls.
Thank you.
10 REPLIES 10
Highlighted
by Contributor
Re: Unlocking your mobile phone or device – The EE quick guide
Thank ou.
Highlighted
@Mvas  What device?
And if it's a iPhone 4 you need to connect the device to iTunes on a PC with a different network provider SIM card in the device as the iPhone 4 can not perform a over the air network unlock.   Follow the on screen prompts that pop up within iTunes to complete the unlock.
Highlighted
by Contributor
Highlighted
by Contributor
It's an iPhone 4
Highlighted
Re: Phone still not unlocked
@Mvas: Did you buy this device yourself new direct from EE or is it 2nd hand? Are you in UK?
Highlighted
@Mvas. Read the edited post I've put up and use a o2 or vodaphone SIM card as 3 SIM card don't always work when performing network unlock.
Highlighted
by Contributor
It was brand new direct from Tmobile bought my hy husband for me, still using it as a second phone still on EE pay as you go(now) but it was a 2 year contract from T mobile, since the contract end I switch to pay as you you with the same provider.
Highlighted
@Mvas   If the device has been unlocked then you need to do as I have instructed, the iPhone 4 cannot perform an over the air unlock and you have to do this through iTunes on a PC.
@XRaySpeX  The device is already unlocked but the unlock has not been preformed on the device yet as it needs to connect to iTunes to complete the unlock.
Highlighted
@Chris_B: Just checking Smiley Wink! OK?
Highlighted
@XRaySpeX  That's ok.
 But @Mvas did say it's been done already.  The problem is that EE unlock information is about over the air unlocks with the iPhone and they only work on the iPhone 5 and above so if you use that for the iPhone 4s and below it will not work and iTunes has to be used.  OK.
