Highlighted
New Member
Phone data
I was just wondering how I can check how much data I have being using on my old sim for apps like "maps"?
Highlighted
by Profile closed
Not applicable
Re: Phone data
Hello @Stwman what phone do you have? You should be able to view how much data each app has used under the mobile data settings. 🙂
Highlighted
by Profile closed
Not applicable
Re: Phone data
Whilst EE don't differentiate between different types of data, you can get your total data usage by browsing to http://add-on.ee.co.uk/status on the EE device.
Highlighted
EE Employee
Re: Phone data
Hi @Stwman and welcome to the Community.
On my android device I can see my usage by the following steps
Go to settingsGo to settingsSelect mobile dataSelect mobile data4G usage ranking4G usage rankingHow much data each app usesHow much data each app uses
Each device may differ in what steps should be taken, but I have used mine as an example.
Many thanks,
Lee
