by wirral59 Investigator
Phone Number problem
My phone number in about phone is 00000000000 how do I change it to my number In contacts it changes to 00000000000 if I reboot my phone
7 REPLIES 7
Re: Phone Number problem
@wirral59  Call customer services ( tomorrow now there closed) and ask them to reset your line.
Thanks I did that today but its still not changing
Sent from my Samsung Galaxy smartphone.
Morning @wirral59
Is this still the same this morning?
If so, are you with us on a pay as you go or pay monthly account?
Speak soon, Leanne 🙂
Hi I'm on a contract
Great thanks @wirral59
I have sent you a private message on here to get some further details.
Speak soon.
by Brt5586 Established Contributor
I had this exact problem and fixed it with live chat. Tell the EE support technician your SIM card serial number on the back just a bunch of numbers (from your sim) then say it's showing on all devices as 000000000000 and tell them to send a network reset and to modify number. They should understand what you mean and after a few hours/30 mins it should show after restart!
Thank you I will try that I have had a network refresh off them but it never worked I spoke to EE this morning and they said they can't do anything there end I was advised to put my sim in a different phone and then to put it back in mine and it should reset it
