by Paul29
PAYG
If I do not use my full top up amount, is it carried over or do I lose it at the end of a month ?
Solution
Re: PAYG
@Paul29: Your PAYG credit is yours to spend as & when you will, on packs or as normal PAYG calls & texts at standard rates. However your pack allowances of mins, texts & data expire at the end of the pack duration whether you use them or not.
6 REPLIES 6
by Ace Contributor
Re: PAYG
HI,
@Paul29
Pay as you go credit carried over next month.
And any un used credit can be use in next month.
Solution
Re: PAYG
Re: PAYG
Morning @Paul29
I can see you have had some great advice.
Let us know if you have any further queries 🙂
by Paul29
Re: PAYG
Many thanks, perfect answer.
Re: PAYG
Glad you got the help you needed @Paul29
Have a great bank holiday weekend 🙂
Re: PAYG
Thanks! You're welcome :)! Glad I could be of assistance.
