by Oliver_James93 Investigator
Order placed
I have placed an order and it says that it's on its way. Does this mean it's definitely been accepted?
by Ace Contributor
Re: Order placed
Hello @Oliver_James93 yes your order has been accepted if you have received the confirmation email containing an XKN order reference number.
Re: Order placed
Ok thank you
by Ace Contributor
Re: Order placed
You are welcome. The community is here anytime if there is anything else you would like to know.
EE Employee
Re: Order placed
Hi and welcome to the community @Oliver_James93
I'm glad you got the brilliant advice above 🙂
Many thanks,
Lee
