by Shybutfast Contributor
Orange livebox triangle light flashing
  1. I have an old orange livebox lost internet today and the triangle light is flashing constantly
Solution
Re: Orange livebox triangle light flashing
The new router cured my problem. I'm not surprised my livebox died it was only about 10yrs old😁
7 REPLIES 7
Dunno the Livebox but isn't the triangle light the power light, I'm guessing? Haven't you kept the guide?
Sounds like it's faulty & you need to call EE for a replacement router.
I try and connect with my iPhone and it sometimes finds the connection For WANADOO-2020 then asks for the password, I enter the password to join but it just keeps asking for the password again and again until it fails to connect. The router I have is the white triangler one. And the light I have flashing is a triangle with an exclamation mark inside it. And it's not mentioned in the guide.
Hi @Shybutfast
Thanks for taking the time to join community 🙂
In addition to the information and advice given by @XRaySpeX
Have you seen the Livebox - connection not working help and support pages we have?
  • Exclamation light off. It looks like there is a problem. Try returning your Livebox to default settings.
Let me know how you get on.
Richard
EE are sending me a new router. Thanks for the link. I hope the new router solves my issue.
Sent from my iPhone
Me too @Shybutfast
Hope to see you again soon in community (not for the same problem though) ha ha.
Fingers crossed this will fix things.
Cheers
Richard
Solution
Morning @Shybutfast
Thanks for letting us know 🙂
Glad you are all sorted now!
