by Taslima Investigator
O2 sim working on iphone6s after unlock request. didn't show msg(it's unlocked)?
Requested to unlock my iphone6s with EE. Texted giving a link to follow instruction to unlock. I put o2 sim in the phone and it's working but it didn't show any msg saying it's unlocked but the o2 sim working on the phone. I'm confused . Is it really unlocked ?
EE Employee
Solution
Re: O2 sim working on iphone6s after unlock request. didn't show msg(it's unlock
Hi @Taslima and welcome to the community.
A country lock is something I have not come across, an unlocked device will work as long as the country you are in supports the bandwidth as mentioned by @Chris_B
Bangladesh support the following:
2G capabilities
GSM 900, GSM 1800
3G capabilities
UMTS 2100
4G capabilities
N/A
Hope this helps,
Lee
It's unlocked if it works with an O2 SIM. Nothing says "I'm unlocked!".
Ooh k. But I'm traveling to Bangladesh and I will b using that county's sim. Will it work in the phone. Or this unlocking is just for uk networks?
@Taslima  If it’s unlocked it will work with any SIM card from anywhere providing that the network that the SIM card is in supports the bandwidth of the device you are using.
I have another question . What is country lock? Is it different to usual phone unlocking I did?
EE Employee
Solution
2G capabilities
GSM 900, GSM 1800
3G capabilities
UMTS 2100
4G capabilities
N/A
Hope this helps,
Lee
