Highlighted
by Investigator
Nokia 3310 APN settings
Can anyone share the settings for this phone please? I bought a sim free one from carphone warehouse and although it appears to have some EE settings in it, the phone isn't connecting to the internet.
I've searched for the APN settings and found a load for android, windows, blackberry etc but none seem to work.
It won't be a big deal if I can't get internet working on it as it's only a dumb phone for work calls, but it'd be nice if I could get it set up properly.
23 REPLIES 23
Highlighted
by Investigator
Re: Nokia 3310 APN settings
Just to add, there doesn't appear to be anywhere for me to enter the MCC or MNC if that helps. Oh and the authentication type options are either normal or secure.
Highlighted
by Profile closed
Not applicable
Hello @Rob83 most EE devices work this these settings, leaving all others blank or set to default:
Profile Name: EE
APN: everywhere
IP Type: IPv4
Sign In Type: PAP
For authentication leave as default or try both. 🙂
Highlighted
by Ace Contributor
@Rob83
Please click here http://setup-ee.wdsglobal.com/internet?step=modelselection.vm&contractId=230&countryId=36&networkId=...
inter security and your number and then send settings on your phone also remember password that you will see on that screen to install that settings in your phone,
Many Thanks
Highlighted
by Investigator
Thanks Tom but unfortunately no joy. Profile, APN and IP are all matching but there's no sign in type option. I've switched between the two authentication types and it's still not having it.
Highlighted
by Ace Contributor
@tahirmian wrote:
@Rob83
Many Thanks
Hi. @Rob83
Have you try above method?
Many Thanks
Highlighted
by Investigator
Hi tahirmian, I may be overly cautious here but I'm hesitant to click that link as I've never heard of 'wdsglobal.com' and as it's not a genuine EE domain, I'd rather not click it unless an EE rep can verify that it's safe.
No offence if it is legit, I just don't take chances on links I don't recognise
Highlighted
by Ace Contributor
@Rob83 That is EE Own link you can use that with out any worry http://setup-ee.wdsglobal.com/internet
Many Thanks
Highlighted
Hi @Rob83,
Welcome to the EE Community. Smiley Happy
The link @tahirmian has posted is genuine.
Highlighted
by Ace Contributor
@James_B
Thank You.
Highlighted
by Investigator
Thanks both, best to be safe than sorry Smiley Happy
I'll give the link a go soon and report back in a bit
Highlighted
No problem @tahirmian
Have a nice weekend. Smiley Happy
Highlighted
by Investigator
Forgot to update, following that link didn't work either, sadly. It added a fresh APN to my phone but it's still not connecting.
Highlighted
by Ace Contributor
@tahirmian wrote:
@Rob83
Many Thanks
@Rob83
What error you get now? have you trun your phon data on? please check that  Menu > > Connectivity> Mobile data, and switch Mobile data connection to Off/On
Many Thanks
Highlighted
by Investigator
Hi, everything is as it should be but I get no error, it just doesn't fetch a data connection and the browser consequently fails to load.
Having just tried a colleague's company SIM card, that won't connect either, despite both sims getting data connections on other phones.
I'll try my own personal SIM this evening, then I'll know if it's the phone or the company sims.
Highlighted
by Investigator
Ok so it's bugging me and I decided to try my own SIM now. It works, so it's not the phone. Thing is, the company sims got data connections on their old phones but not the Nokia. A data connection can't be restricted so it only works on a specified handset, can it?
Highlighted
@Rob83. If it works on one sim it should work with any sim it’s not handset specific.
Highlighted
by Investigator
Well what can I say, it's not working with my company SIM, nor my colleague's, but it works with my personal SIM. I thought I knew my way around APN settings and such, but this has me stumped.
Highlighted
Hi @Rob83,
It's got me stumped too!
If it works with one EE SIM, it should work with another.
Please get in touch with customer services and our technical team will be happy to look into this in more detail.
Let us know how you get on.
Highlighted
by Profile closed
Not applicable
Hello @Rob83 if both yours and your colleagues lines are not working and they are pay monthly lines they could be new EE IPv6 lines which are not compatible with some devices. Customer service can help further if this is the case. 🙂
