No signal on iPhone 5c
I have picked up my iPhone 5c on an upgrade this morning, put in my SIM card but it won't pick up any signal. My 3GS is still working and shows full signal, does anyone have any idea what I am doing wrong....???
Community Hero
Re: No signal on iPhone 5c
[ Edited ]
Need a bit more info from you first.
Are you switching from T-Mobile or Orange to 4GEE or it this just a T-Mobile or Orange upgrade?
Have you activated your iPhone?  You need to either follow the initial on-screen set-up wizard or sync it with iTunes.
Hi, yeah switching from t mobile to EE. Was assured it will work straight away though..!?
Set up iPhone as usual and restored from icloud.
Thanks.
Community Hero
[ Edited ]
Using your T-Mobile SIM card in your old handset, you need to send a text with the word SWITCH to 3333 to start the SIM transfer process. It can take upto 24hrs, but usually takes less than an hour. You will receive a response from EE then your T-Mobile service will disconnect, your 4GEE SIM card should then start working.
I've just tried that but it wouldn't deliver...?
(But thanks)
Recent solutions
Subject
991
0
5994
1
10589
0
2017
1
