Highlighted
by Investigator
No option to turn on Wi-Fi Calling in Call Settings on my Galaxy S7
I have recently upgraded to a Galaxy S7 and there is no option to turn on Wi-Fi Calling in the Call Settings Menu. I have tried starting the machine in Safe Mode and all of my Updates have been done but there is still nothing in the Call Setting menu. It's really frustrating as I have absolutely no signal at work.
7 REPLIES 7
Highlighted
by Star Contributor
Star Contributor
Re: No option to turn on Wi-Fi Calling in Call Settings on my Galaxy S7
Hi @Hatterfan88
Did you get your phone directly from EE?
Thanks,
Martyn
Highlighted
by Investigator
Yes I did and I had in on my old S5 no problems.
Highlighted
by Star Contributor
Star Contributor
Hi @Hatterfan88
If you haven't done so already, do a software update.
Thanks,
Martyn
Highlighted
by Investigator
All software updates have been done, there are none available to me when I select this option from the settings.
Highlighted
by Star Contributor
Star Contributor
@Hatterfan88
login to your account then see if you can chat to an advisor.  They maybe an issue with your account.
Thanks,
Martyn
Highlighted
Hi @Hatterfan88
Let us know how you get on when you speak to customer services @martyn413 is right and I think this needs looked at.
Cheers
Richard
Highlighted
Enter *#1234# into the dialer and post the code.
Are you also pay monthly or PAYG?
