by Leogold
New contract
I ordered the iPhone 6 plus to an ee store and due to some issues, it had to sent back to warehouse for processing and then sent to my home address. How long will it take to get to the warehouse? And when it does can I change the 6 plus to the 8 plus or X?. Thanks
Solution
Re: New contract
@Leogold
You will need to call CS on 150 and speak to them. If your order is processed then you would need to return it within 14 days to be able to upgrade to a different handset, subject to stock.
If it's not processed then you maybe able to change it before its sent. Either way you should speak to CS.
Re: New contract
If you have ordered via an EE retail store you will need to take this up with them direct as they are separate unit from the online store. Tye same will go for timescales and if you can change your order.
If you ordered online then you would need to speak to CS on 150 about all the issues.
by Leogold
Re: New contract
Hi @Northerner, I did it online not in the store.
Thank you
Solution
Re: New contract
@Leogold
by Leogold
Re: New contract
H @Northerner, okay I will do that. Thank you for replying and for the help.
Re: New contract
Hi @Leogold
Welcome to the community. 🙂
Did you get sorted by calling up?
Chris 🙂
