My sony xperia sp wont charge or turn on
My sony xperia sp randomly turned off and won't turn on at all, i tried charging it but when i plug it in a red light flickers all the time and nothing happens, i tried everything and still nothing.
Re: My sony xperia sp wont charge or turn on
The red light that indicates charging turns off after a while.
Scholarly Contributor
charge for 20 mins to a hour and then switch on.
This happens when the battery is too low to switch on.
If you think I helped please take time to press the button below.
Take the 60 second EE Community Survey, let us know what you think
Community guidelines
Community stars programme Meet the EE Community team How to use the community
EE Facebook
EE Twitter
I charged my phone all night and nothing...
I charged my phone for 20 minutes and nothing...
Also, when i plug in my usb cable to my laptop, my laptop does not detect my phone for some reason
Open the back panel.
towards the bottom on the centre there will be a pin hole reset button.
press that for a few seconds till the phone vibrates and that should reset the phone.
Once that is done charge the phone for 10 mins and then switch on.
EE Facebook
EE Twitter
i tried that and still nothing
the phone doesn't even vibrate
i held it for five minutes...
my pc doesnt even recognize my phone for some reason
[ Edited ]
when i plug my phone in, a noise on the laptop pops up that indicates the usb is plugged in, but then another noise pops up that indicates that the usb has been removed...
Did you try to flash another rom and did it brick the device?
Have you tried reflashing back to stock firmware using the SUS / Flashtools ?
EE Facebook
EE Twitter
New Member
Hey when you reset your phone by presssing that button did it reset everything? like did you lose you photos and stuff? please help!!
Brilliant Contributor
Anything on the external SD card should be fine.
Always back up media, contacts etc stored on the internal memory.
I resolved the problem by taking a small plastic brush that came supplied with my hair clippers and slightly moistened it using water. Be sure only to use a very small amount of water. I then inserted the brush into the micro USB port on my phone and also inside the micro USB connector teeth. The twisting action throughly cleaned the insides and removed all the dirt and grease accumulated when the phone was inside my pocket. My Sony Xperia SP now charges without any problems and so should yours. Good luck!
New Member
[ Edited ]
I have had exactly the same issue with an Xperia P Lt22i and solved it the same way, with a moist tooth brush (and not even a new one). I have to admit I will further use the tooth brush for my mouth hygiene.
Recent solutions
Subject
991
0
5994
1
10589
0
2017
1
