Highlighted
My mobile data hasn't reset it was suppose to on the 27th November Why
My mobile data was suppose to switch back on 27th November I had it switched off while using wifi because I ran out why as it not reset
Highlighted
by Ace Contributor
Re: My mobile data hasn't reset it was suppose to on the 27th November Why
HI @Mandiejgraham
Some time it take time reset data allowance.
You can check your data allowance click on the link below.
http://add-on.ee.co.uk
On your mobile Internet not on WiFi.
Highlighted
I don't have any mobile Internet left so when I switch off WiFi I go offline
Sent from my Sony Xperia™ smartphone
Highlighted
You can get to http://add-on.ee.co.uk even w/out data. It's inside EE's network.
Highlighted
Great answers @tahirmian and @XRaySpeX
I hope this helps you get sorted out.
Thank you
Richard
